Ardumower Sunray
Version vom 26. Februar 2020, 12:57 Uhr von Alexanderg (Diskussion | Beiträge) (→‎XBee RF modules issues)
PCB     PCB
  • Optimized for Arduino Due
PCB     PCB
You can change the message rates at the base via the configuration of the CFG-MSG message, choosing the above RTCM3 message and setting zero (0) to turn a a RTCM3 message off or a non-zero rate value for the message rate. For example setting the rate to 1 means every second, 2 means every two seconds etc. Do not forget to send and save the base configuration.
600px
