Ardumower Sunray
Version vom 1. März 2020, 14:18 Uhr von Alexanderg (Diskussion | Beiträge) (→‎How the waypoints are generated)
  • Optimized for Arduino Due
PCB     PCB
XBee RF modules issues
We are currently experimenting with different GPS antennas for the rover. The helical and survey antennas seem to perform slightly better than the normal patch antennas. A RTK-FIX solution is obtained more quickly and hold longer in challenging lawn environments with them.
This might be the right hack for you :-) This is how I added an external SMA antenna to my bluetooth module. Happy hacking :-)
Recording perimeter polygon and exclusions polygons
600px
