Ardumower Sunray
Version vom 7. März 2020, 19:23 Uhr von Alexanderg (Diskussion | Beiträge) (→‎RTK float-to-fix recovery issues)
PCB Environment 'AG' (mostly open sky)
PCB Environment 'ML' (slightly limited sky view, higher nearby buildings and trees)
  • Optimized for Arduino Due
PCB     PCB
XBee RF modules issues
We are currently experimenting with different GPS antennas for the rover. The helical and survey antennas seem to perform slightly better than the normal patch antennas. A RTK-FIX solution is obtained more quickly and hold longer in challenging lawn environments with them.
Optional: You can install an IMU (MPU6050) like shown below to improve short-term direction measurements:
Recording perimeter polygon and exclusions polygons
600px
