Ardumower Sunray
Version vom 7. April 2020, 08:55 Uhr von Alexanderg (Diskussion | Beiträge) (→‎What are the differences between the ArduSimple and Ardumower ublox receiver configurations)
PCB Environment 'AG' (mostly open sky)
PCB Environment 'ML' (slightly limited sky view, higher nearby buildings and trees)
  • Optimized for Arduino Due
6. Connect the rover PCB via USB to your PC, and make sure NMEA protocol out is activated for UART2 out at 115'200bps (configuration view-> message 'PRT (Ports)'). Also make sure NMEA GGA message is active active on UART2 (configuration view->message 'MSG (Messages)'->F0-00 NMEA GxGGA). Some NTRIP service providers need this NMEA message to compute a virtual base station (VRS) based on the initial estimated GPS fix position.
7. Finally, verify the LED 'XBEE-GPS' is blinking (the rover receives correction data) and the correction age (seconds) shown near the fix solution in the phone app is not increasing. If it does NOT work:
8. If your NTRIP base antenna position is not constant, you have to switch to position source mode 'absolute' in the App (see section App for more details).
    1074: GPS MSM4
    1084: GLONASS MSM4
    1094: GALILEO MSM4
    1124: Beidou MSM4
    1230: GLONASS code-phase
PCB     PCB
01-12 UBX-NAV-VELNED
01-14 UBX-NAV-HPPOSLLH
XBee RF modules issues
Recording perimeter polygon and exclusions polygons
600px
How the path finding works
600px
600px
identical
  F0-00 F0-00 NMEA GxGGA
measurement period: 200ms (5 Hz)
baudrate UART1: 115200
baudrate UART2: 115200
protocol out UART2: NMEA
protocol in UART2: RTCM3
