Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 14 How to record perimeter and exclusions
- 15 Odometry test
- 17 RTK float-to-fix recovery issues
- 21 IMU, sensor fusion
- 22 Recording perimeter polygon and exclusions polygons
- 23 How the waypoints are generated
- 24 How the path finding works
- 25 How the obstacle avoidance works
- 26 What are the differences between the Ardumower and ArduSimple ublox receiver configurations
- 27 Discussion / questions / forum thread
- Optimized for Arduino Due
Nordrhein Westfalen (SAPOS HEPS): VRS_3_4G_NW Niedersachsen (SAPOS HEPS): VRS_3_2G_NI Berlin (SAPOS HEPS): VRS_3_2G_BE
6. Save configuration and reset the system. From now on, every time the WiFi hotspot you configured is in range, the WiFi NTRIP Master will connect autonomously and provide RTK corrections to your rover PCB.
1074: GPS MSM4
1084: GLONASS MSM4
1094: GALILEO MSM4
1124: Beidou MSM4
1230: GLONASS code-phase
Video: Tutorial: How to use the app video (German with English subtitles)
identical
additional activated messages for UART1+USB: 01-12 UBX-NAV-VELNED 01-14 UBX-NAV-HPPOSLLH 01-3C NAV-RELPOSNED 02-32 RXM-RTCM additional activated messages for UART2+USB: F0-00 F0-00 NMEA GxGGA measurement period: 200ms (5 Hz) baudrate UART1: 115200 baudrate UART2: 115200 protocol out UART2: NMEA protocol in UART2: RTCM3
