Ardumower Sunray
Version vom 12. April 2020, 20:29 Uhr von Alexanderg (Diskussion | Beiträge) (→‎What is RTK and what are the requirements (environment and hardware))
'Mows like on rails...' This is an RTK GPS-based mower that you can build yourself. Ardumower RTK doesn't need a perimeter wire as it uses (cm-precise) RTK GPS. Icons experimental.png
PCB Environment 'AG' (mostly unobstructed sky)
PCB Environment 'ML' (partial obstructed sky view, higher nearby buildings and trees)
  • Optimized for Arduino Due
    1074: GPS MSM4
    1084: GLONASS MSM4
    1094: GALILEO MSM4
    1124: Beidou MSM4
    1230: GLONASS code-phase
PCB     PCB
01-12 UBX-NAV-VELNED
01-14 UBX-NAV-HPPOSLLH
600px
How the path finding works
600px
600px
identical
  F0-00 F0-00 NMEA GxGGA
measurement period: 200ms (5 Hz)
baudrate UART1: 115200
baudrate UART2: 115200
protocol out UART2: NMEA
protocol in UART2: RTCM3
