Ardumower Sunray
NOTE: This is software is still in EXPERIMENTAL state!
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 15 Odometry test
- 17 RTK float-to-fix recovery issues
- 21 IMU, sensor fusion
- 25 What are the differences between the Ardumower and ArduSimple ublox receiver configurations
- 26 Discussion / questions / forum thread
- Optimized for Arduino Due
Nordrhein Westfalen (SAPOS HEPS): VRS_3_4G_NW Niedersachsen (SAPOS HEPS): VRS_3_2G_NI Berlin (SAPOS HEPS): VRS_3_2G_BE Baden Württemberg (SAPOS HEPS): VRS_3_2G_BW
1074: GPS MSM4
1084: GLONASS MSM4
1094: GALILEO MSM4
1124: Beidou MSM4
1230: GLONASS code-phase (this message could be missing - then 1033 should be received instead!)
Optional: You can install an IMU (MPU6050 / MPU9150 / MPU9250 / MPU9255) like shown below to improve short-term direction measurements (in addition to wheel odometry). NOTE: IMU support has not been tested thoroughly (for a longer duration) yet. Make sure to configure the correct module in 'config.h'. For the shop module, choose MPU9255 in 'config.h'. If you IMU was found correctly, you should hear 8 short buzzer beeps at the mower start (automatic gyro calibration).
identical
additional activated messages for UART1+USB: 01-12 UBX-NAV-VELNED 01-14 UBX-NAV-HPPOSLLH 01-3C NAV-RELPOSNED 02-32 RXM-RTCM additional activated messages for UART2+USB: F0-00 F0-00 NMEA GxGGA measurement period: 200ms (5 Hz) baudrate UART1: 115200 baudrate UART2: 115200 protocol out UART2: NMEA protocol in UART2: RTCM3
