Ardumower Sunray
Version vom 26. Mai 2020, 20:30 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Rover configuration (messages))
  • Optimized for Arduino Due
PCB     PCB
01-12 UBX-NAV-VELNED
01-14 UBX-NAV-HPPOSLLH
Default setting:           Minimum number satellites required with 0 dbHz: 0
More restrictive setting:  Minimum number satellites required with 30 dbHz: 10
Longer battery operation time
600px
How the path finding works
600px
600px 400px
600px
MSG (messages):
  F5-05 RTCM3.3 1005
  F5-4A RTCM3.3 1074
  F5-54 RTCM3.3 1084
  F5-5E RTCM3.3 1094
  F5-7C RTCM3.3 1124
  F5-E6 RTCM3.3 1230
MSG (messages)
            baudrate UART2: 115200
            protocol out UART2: NMEA
            protocol in UART2: RTCM3
