Ardumower Sunray
NOTE: This is software is still in EXPERIMENTAL state!
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 15 Odometry test
- 17 RTK float-to-fix recovery and false-fix issues
- 21 IMU, sensor fusion
- 24 How the waypoints are generated
- 25 How the path finding works
- 26 How the obstacle avoidance works
- 27 How the line tracking works
- 28 What data is transferred to the Arduino
- 29 What are the differences between the Ardumower and ArduSimple ublox receiver configurations
- 30 Discussion / questions / forum thread
- Optimized for Arduino Due
For your first NTRIP tests (or even as permanent installation), you might use a portable 4G/WiFi router. Such 4G modem could be used where the WiFi coverage is limited. In addition, you can operate multiple WiFi devices (Ardumower PCB WiFi module, NTRIP client WiFi module, ESP32-CAM WiFi module etc.) via this portable 4G WiFi router.
A Stanley controller is used to precisely track the lines between the waypoints:
MSG (messages)
baudrate UART2: 115200
protocol out UART2: NMEA
protocol in UART2: RTCM3
