Ardumower Sunray
WARNING!
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 15 Odometry test
- 17 RTK float-to-fix recovery and false-fix issues
- 21 IMU, sensor fusion
- 24 How the waypoints are generated
- 25 How the path finding works
- 26 How the obstacle avoidance works
- 27 How the line tracking works
- 28 What data is transferred to the Arduino
- 29 What are the differences between the Ardumower and ArduSimple ublox receiver configurations
- 30 Discussion / questions / forum thread
- Optimized for Arduino Due
A Stanley controller is used to precisely track the lines between the waypoints:
MSG (messages)
baudrate UART2: 115200
protocol out UART2: NMEA
protocol in UART2: RTCM3
