Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 WiFi module
- 8 PCB1.3 GPS pin fix
- 9 PCB1.3 odometry divider
- 10 RTK base
- 11 RTK rover
- 14 Phone App
- 16 Odometry test
- 17 RTK GPS test (invalid, float, fix) and FIX robustness and correctness
- 18 RTK float-to-fix recovery and false-fix issues
- 19 XBee RF bandwidth/corruption issues
- 20 GPS antenna selection guide
- 21 Bluetooth Low Energy (BLE) external antenna hack
- 22 IMU, sensor fusion
- 23 Portable WIFI router for NTRIP
- 24 Longer battery operation time
- 25 How the waypoints are generated
- 26 How the path finding works
- 27 How the obstacle avoidance works
- 28 How the line tracking works
- 29 What data is transferred to the Arduino
- Optimized for Arduino Due
- the lateral error (distance from the planned (green) line - see yellow arrows below)
- the angular error (angle to the goal/target - see red arrows below)
MSG (messages)
baudrate UART2: 115200
protocol out UART2: NMEA
protocol in UART2: RTCM3
