Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 15 Odometry test
- 17 RTK float-to-fix recovery and false-fix issues
- 21 IMU, sensor fusion
- 24 WiFi module (optional)
- 25 How the waypoints are generated
- 26 How the path finding works
- 27 How the obstacle avoidance works
- 28 How the line tracking works
- 29 What data is transferred to the Arduino
- Optimized for Arduino Due
Optionally, you can add a ESP8266-01 WiFi module (found in the shop) to your PCB1.3 and use it with the Sunray firmware:
If you experience connection issues, you may have to add an additional capacitor (e.g. 470 uF/10V) to the module as shown in the photo.
Look into firmware file 'config.h' on how to configure SSID and (a static) IP. Also, look into the serial console (Download section, step 7) if you experience connection issues.
- the lateral error (distance from the planned (green) line - see yellow arrows below)
- the angular error (angle to the goal/target - see red arrows below)
MSG (messages)
baudrate UART2: 115200
protocol out UART2: NMEA
protocol in UART2: RTCM3
