Ardumower Sunray
Version vom 10. Juli 2020, 10:39 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Map pattern, pattern angle, mowing offset)
  • Optimized for Arduino Due
01-12 UBX-NAV-VELNED
01-14 UBX-NAV-HPPOSLLH
Longer battery operation time
How the path finding works
This section describes (simplified) the 'rubber-band' path-finder algorithm that computes the path finding from one source point to some destination point considering obstacles (perimeter and exclusion polygons). Among other things, the path finding is used to compute:
  • the path from one ring to another
  • the path from current robot position to docking station and from docking station back to current mowing position
  • the path around dynamic obstacles
Click here for path finder demonstration video
500px
How the line tracking works
  1. the lateral error (distance from the planned (green) line - see yellow arrows below)
  2. the angular error (angle to the goal/target - see red arrows below)
600px
600px
MSG (messages):
  F5-05 RTCM3.3 1005
  F5-4A RTCM3.3 1074
  F5-54 RTCM3.3 1084
  F5-5E RTCM3.3 1094
  F5-7C RTCM3.3 1124
  F5-E6 RTCM3.3 1230
MSG (messages)
            baudrate UART2: 115200
            protocol out UART2: NMEA
            protocol in UART2: RTCM3
