Ardumower Sunray
Version vom 26. August 2020, 20:30 Uhr von Alexanderg (Diskussion | Beiträge) (→‎What is RTK and what are the requirements (environment and hardware))
Ardumower Sunray is an alternative Firmware (experimental) for the Ardumower DIY robotic mower system. It uses RTK GPS to localize cm-precise without a perimeter wire. It requires Ardumower PCB1.3, Arduino Due (or Adafruit Grand Central M4), Ardumower RTK kit, Bluetooth BLE and a phone (Android/iOS).
  • Optimized for Arduino Due (and Adafruit Grand Central M4)
6. Connect Arduino Due USB native port to your Computer's USB port. Upload the sketch to your Arduino Due on the Ardumower PCB1.3. After a short while you should hear a 'beep'. Ardumower is now ready for your commands!
Longer battery operation time
