Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 14 Odometry test
- 15 Position source mode
- 16 Record perimeter and exclusions
- 17 Mowing pattern, pattern angle, mowing offset
- 20 GPS checksum errors
- 23 IMU, sensor fusion
- 27 Docking
- 28 WiFi module
- 31 Troubleshooting
- 32 How to record GPS data
- 33 Datasheets
- 34 Data privacy
- 35 Discussion / questions / forum thread
- Ardumower chassis kit using Ardumower motors (incl. odometry) and PCB 1.3 (incl. Arduino Due/Adafruit Grand Central M4 and MC33926 motor drivers)
Ardumower Sunray is an alternative Firmware (experimental) for the Ardumower DIY robotic mower system. It uses RTK GPS to localize cm-precise without a perimeter wire. It requires Ardumower PCB1.3, Arduino Due (or Adafruit Grand Central M4), Ardumower RTK kit, Bluetooth BLE and a phone (Android/iOS).
- Optimized for Arduino Due (and Adafruit Grand Central M4)
6. Connect Arduino Due USB native port to your Computer's USB port. Upload the sketch to your Arduino Due on the Ardumower PCB1.3. After a short while you should hear a 'beep'. Ardumower is now ready for your commands!
F5-4A RTCM3.3 1074 GPS MSM4 1
F0-00 NMEA-GxGGA 10
01-3C UBX-NAV-RELPOSNED 1
01-43 UBX-NAV-SIG 10
02-32 RXM-RTCM 5
Min SV elevation 10 OR 10 (hartmut config)
C/N0 Threshold #SVs 10 OR 0 (hartmut config)
dbHz 30 OR 10 (hartmut config)
