Ardumower Sunray
Version vom 30. August 2020, 13:33 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Significant changes compared to Ardumower's initial firmware (Sunray vs. Azurit))
6. Connect Arduino Due USB native port to your Computer's USB port. Upload the sketch to your Arduino Due on the Ardumower PCB1.3. After a short while you should hear a 'beep'. Ardumower is now ready for your commands!
Longer battery operation time
