Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 14 Odometry test
- 15 Position source mode
- 16 Record perimeter and exclusions
- 17 Mowing pattern, pattern angle, mowing offset
- 20 GPS checksum errors
- 23 IMU, sensor fusion
- 24 Ultrasonic sensor
- 25 Extending WiFi range with outdoor access point
- 26 Portable WiFi router for NTRIP
- 27 Longer battery operation time
- 28 Docking
- 29 WiFi module
- 30 Bluetooth Low Energy (BLE) and WiFi external antenna hacks
- 31 What are the differences between the Ardumower and ArduSimple ublox receiver configurations
- 32 Troubleshooting
- 33 How to record GPS data
- 34 Datasheets
- 35 Data privacy
- 36 Discussion / questions / forum thread
6. Connect Arduino Due USB native port to your Computer's USB port. Upload the sketch to your Arduino Due on the Ardumower PCB1.3. After a short while you should hear a 'beep'. Ardumower is now ready for your commands!
F5-4A RTCM3.3 1074 GPS MSM4 1
F0-00 NMEA-GxGGA 10
01-3C UBX-NAV-RELPOSNED 1
01-43 UBX-NAV-SIG 10
02-32 RXM-RTCM 5
Min SV elevation 10 OR 10 (hartmut config)
C/N0 Threshold #SVs 10 OR 0 (hartmut config)
dbHz 30 OR 10 (hartmut config)
