Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 Adafruit Grand Central M4
- 10 RTK base
- 11 RTK rover
- 14 Phone App
- 15 Odometry test
- 16 Position source mode
- 21 GPS checksum errors
- 24 IMU, sensor fusion
- 25 Ultrasonic sensor
- 29 Docking
- 30 WiFi module
- 33 Troubleshooting
- 34 How to record GPS data
- 35 Datasheets
- 36 Data privacy
- It is recommended to upgrade the bootloader on the Adafruit Grand Central M4 board. Download the the latest bootloader file here (look at the bottom of this link for .UF2 bootloader file): https://circuitpython.org/board/grandcentral_m4_express/
F5-4A RTCM3.3 1074 GPS MSM4 1
F0-00 NMEA-GxGGA 10
01-3C UBX-NAV-RELPOSNED 1
01-43 UBX-NAV-SIG 10
02-32 RXM-RTCM 5
Min SV elevation 10 OR 10 (hartmut config) 10 (default)
C/N0 Threshold #SVs 10 OR 0 (hartmut config) 0
dbHz 30 OR 10 (hartmut config) 0
