Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 Adafruit Grand Central M4
- 10 RTK base
- 11 RTK rover
- 14 Phone App
- 15 Odometry test
- 16 Position source mode
- 21 GPS checksum errors
- 24 IMU, sensor fusion
- 25 Ultrasonic sensor
- 29 Docking
- 30 WiFi module
- 31 SD card module
- 34 Troubleshooting
- 35 How to record GPS data
- 36 Datasheets
- 37 Data privacy
- 39 SD card logging
- 40 Hardware debugging
5. Remove any JP12 (GPS signal) jumpers (please ignore the photo for this jumper - we will not use the level shifter, see section GPS pin fix further below)
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin
F0-00 F0-00 NMEA GxGGA 60
Optionally, you can add an SD card module (found in the shop to your Arduino Due and use it with the Sunray firmware to save the uploaded map. NOTE: The Adafruit Grand Central M4 already has an SD card reader built-in.
CATALEX MicroSD card Adapter Arduino Due SPI pins
CS ------------------------- Arduino Due pin 46 (chip-select pin, not an SPI pin) SCK ------------------------- SCK MOSI ------------------------- MOSI MISO ------------------------- MISO VCC ------------------------- 5V GND ------------------------- GND
F5-4A RTCM3.3 1074 GPS MSM4 1
F0-00 NMEA-GxGGA 60
01-3C UBX-NAV-RELPOSNED 1
01-43 UBX-NAV-SIG 10
02-32 RXM-RTCM 5
C/N0 Threshold #SVs 10 0
dbHz 30 0
