AzuritBer Firmware (English)
What is AzuritBer and Why
AzuritBer was build for DENNA,ROBOMOW and PARANELLO platform and use Odometry or IMU to control the state change. It can only run on DUE and Odometry is mandatory (minimum 400 ticks per rev).But it's possible to adjust setting to work for other kind of platform.
This version always use odometry into all movement (reverse,roll etc...) . The result is a more smooth movement without pause between all the diffrents state.
At the beginning of the dev i need many debug message to perfectly setup the firmware, so i add a raspberry and record all the mowing duration in a Console. Actually PI is optional, but help a lot to find trouble in the behaviour and to communicate (With your PC,or home automation) Other option is the RFID tag reader that help : To manage up to 3 mowing area without any wire connection between them.(1 Station sender and 2 wifi sender for other area) To help the back to station very fast. To escape from island To change tracking speed (For example reduce just before docking)
First start
For the first start on a new RTC eeprom the firmware use the factory setting value locate into mower.cpp and you need to do a save setting and reboot.
Motor Setting
First step is the Odometry setting:
