AzuritBer Firmware (English)
Version vom 27. Oktober 2020, 19:24 Uhr von Bernard (Diskussion | Beiträge) (→‎First start Level 1)
What is AzuritBer and Why
AzuritBer was build for DENNA,ROBOMOW and PARANELLO platform and use Odometry or IMU to control the state change. It can only run on DUE and Odometry is mandatory (minimum 400 ticks per rev).But it's possible to adjust setting to work for other kind of platform.
This version always use odometry into all movement (reverse,roll etc...) .The result is a more smooth movement without pause between all the diffrents state.
Level 1 Standard
Level 2 Raspberry
It's Level 1 but now:
It's level 2 but now:
First start Level 1
For the first start on a new RTC eeprom and after uploading the sketch,you need to do a save setting and reboot.
Before upload the sketch ,verify that into mower.cpp the line :
Motor Setting
First step is the Odometry setting:
