Ardumower Sunray
Version vom 26. März 2021, 09:36 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Rover configuration (messages))
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin
F0-00 F0-00 NMEA GxGGA    60
Longer battery operation time
Automatic battery switch off
  2. If you need to change the ESP8266 firmware use the following tool: https://www.espressif.com/en/support/download/other-tools (Flash Download Tools). Before starting the flashing procedure, GPIO_0 must be connected to Ground for the entire flashing procedure to enable programming mode. The pins can be found here : https://components101.com/wireless/esp8266-pinout-configuration-features-datasheet. The configuration of the download tool looks like this : Esp8266 firmware flash.png
  3. Make sure you have set the WiFi jumpers (shown here).
  4. If you experience connection issues, you may have to add an additional capacitor (e.g. 470 uF/10V) to the module as shown in the photo. Also, do not use additional cables in between PCB1.3 and WiFi module if you experience connection issues.
  5. Look into firmware file config.h on how to configure SSID and (a static) IP.
  6. Look into the serial console (Download section, step 7) if you experience connection issues and to debug the connection process.
Do the same for messages:
01-43 NAV-SIG
0A-36 MON-COMMS
  • South America: 433 MHz
  • Africa: 433 MHz
  • Asia: 415/433 MHz
  • New Zealand: 917-927MHz
