Chassis 2021
- Wheels: 250mm diameter
- Free wheel: 125mm diameter
- A high torque (2.45Nm) guarantees that the robot can climb small hills as well (with 2 motors, 0.125 radius wheel, 31rpm = 0.4m/s = 1.5 km/h, acceleration = 0.2 ( 1/2 of nominal speed) see calculator
- Battery: Lithium-Ion 29.4V (125Wh or 250Wh)
- Total energy consumption (average): 40W (60W peak, 7W idle)
- Max. incline: approx. 30%
- Overall impression
- Loundness test
- Gear motor test
- Gear motor hardness test
- Mowing motor hardness test
- Robot releases itself
- Plastic blades test
- Rain sensor test
- 3D simulation
Required Tools
- Screw driver
- Different Torx screw driver
- Knife
Optional Tools
- Round and flat file
- Electric padsaw
Optional Material
- M4 washer and spring washer
- 1 M8 carriage bolt
- Rain sensor case 3D print from model
- Case for NTRIP receiver module for GSPS variant of the Ardumower
Case assembly
Gear motors
Tires
Mower motor
Mowing disc
Free wheel
