Ardumower Sunray
Version vom 3. Mai 2021, 00:35 Uhr von Alexanderg (Diskussion | Beiträge) (→‎XBee modules configuration)
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin
  2. Remove jumper Gps_S (JP12)
F0-00 F0-00 NMEA GxGGA    60
Longer battery operation time
volt=24
...some time later...
...many time later...
Automatic battery switch off
Do the same for messages:
01-43 NAV-SIG
0A-36 MON-COMMS
  • South America: 433 MHz
  • Africa: 433 MHz
  • Asia: 415/433 MHz
  • New Zealand: 917-927MHz
XBee modules configuration
The XBee modules on ArduSimple PCB's are already configured. If you need to reconfigure for some reason, here's how to do so:
  1. Download XCTU: https://www.digi.com/xctu
  2. Connect ArduSimple PCB USB (XBee side) to your PC
