Perimeter wire
[Magnetic field calculation http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/magcur.html]
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
Arrangement of coils
Layout of the wire
- Perimeter stop test
- Perimeter tracking test
Principle:
Signal
The sender sends a repeating sequence of a digital code ('pseudonoise4_pw') at 9615 Hz :
Filter
sender circuit:
motor driver Vin o-- 12V
|---------o-- GND
|---------o-- Arduino +5V
Sender current control
Sender automatic standby
Sender software
Sender diagnostics
Receiver
receiver circuit:
LM386 IN o------- capacitor 4.7nF ----------- coil 100 mH
Receiver ADC calibration
Receiver diagnostics
sig: coil signal (raw pulse sequence after ADC)
mag: filter result: inside (negative) or outside (positive), magnitude: distance to perimeter wire (RSSI)
qty: filter quality (how distinguisable inside and outside were in filter result)
