Ardumower PCB
Version vom 12. Februar 2015, 11:12 Uhr von Alexanderg (Diskussion | Beiträge) (→‎PCB 1.0 prototype, jumpers)
Needed parts
  • Main functions
    • 1 x Arduino Mega 2560
    • 1 x MC33926 motor driver module
    • 1 x current sensor module ACS712-5
  • Perimeter sender (optional)
    • 1 x Arduino Nano
    • 1 x Arduino Nano
    • 1 x LM386 amplifier module
    • Capacitor (1 x 4,7nF), 1 x Receiver coil 100mH
  • Additional modules
Schematics
KiCad Files are in the SVN
PCB assembly
The PCB is made with the following design parameters:
  • PCB dimensions 241x114mm
  • All used modules are available in the Ardumower shop
  • Uses the Arduino Mega 2560 (and via adapter the Arduino Due)
More photos to come...
Feature used YES NO Comment
Integrated LM350T charging control D7: DIODE,
D3: DIODE, C1, C4, U4, RV1: used
D7: SHORT-CIRCUIT,
D3: SHORT-CIRCUIT, C1, C4, U4, RV1: not used
Do not use if using external charger
External power while charging JP6: CLOSE,
JP7: OPEN, D4: DIODE
JP6: OPEN,
JP7: CLOSE, D4: not used
Use for external power to your PCB (disconnect battery from PCB) while charging
Arduino controlled charge relay JP4: CLOSE,
JP5: OPEN
JP4: OPEN
JP5: CLOSE
Bluetooth VCC=3.3V JP8: OPEN,
JP9: CLOSE
JP8: CLOSE,
JP9: OPEN
Many latest modules use 3.3V
You have two options:
SVN version download steps:
First-time calibration
Wheel motors
ADC calibration
Diagnostic
  2. loop()-counts per second
  5. drive home? (1/0)
  11. "com" - compass course
  13. "bat" - Battery voltage
  14. "chg" - Charging current
Starting the mower
Error counter / error beeps
I2C bus / error beeps
Config files
  • config.h (old v9.0.3)
  • mower.cpp (SVN version)
pfodApp
