Perimeter wire
Version vom 1. April 2015, 14:35 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Perimeter v2 (for SVN version, recommended))
Magnetic field calculator
Principle:
Signal
  2. increase the signal length
We use a combination of both. The sender sends a repeating sequence of a digital code ('pseudonoise4_pw') at 9615 Hz :
Filter
sender circuit:
               |---------o-- GND
               |---------o-- Arduino +5V
Sender perimeter lawn size
Sender current control
Sender automatic standby
Sender software
Sender diagnostics
Video explaining all steps
Receiver
For receiving the signal, we use a coil (100 mH or 150 mH) in upright position (centered at front in robot), connected through a capacitor (4.7nF) to an LM386 operational amplifier (to amplify the received signal). When using the LM386 module, capacitor C3 on the LM386 module should be bypassed (which is needed so that the LM386 generates a signal between 0..5V and not the default range -5V..+5V). The LM386 output pin should be connected to an analog Arduino pin ('pinPerimeterLeft').
receiver circuit:
NOTE: It's recommended to directly mount the coil on the amplifier module. This ensures the 'small signal' of the coil is not distorted by other components (motors, DC/DC converters etc.)
The signal output of LM386 amplifier should look like this: (for more details about the signal, see section signal above)
Coil
The inductance of 100 mH and capacity of 4.7 nF results in a resonation frequency of 7341 Hz.
The inductance of 150 mH and capacity of 4.7 nF results in a resonation frequency of 5994 Hz.
f0 = 1 / (2 * PI * sqrt(L * C)) = 1 / (2 * PI * sqrt(0.15 H * 0,0000000047 F)) =  5994 Hz
Bandwidth = R / L = 155 Ohm / 0.15 H = 1033 Hz
Receiver ADC calibration
qty:  filter quality (filter min/max ratio - how distinguisable inside and outside were in filter result - 1.0 means poor quality)
  • Adjust input voltage of sender: increase voltage (sender potentiometer) for for longer perimeter (>80m), decrease (sender potentiometer) for shorter perimeter (>25m) - Use 12V sender voltage (max. current), if 'mag' values are too low
  • While motors are running, try to tilt coil slightly to one side so that 'mag' curve improves (gets clearer without spikes)
  1. Perimeter2 demo
  2. 120m perimeter wire test
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
l = coil length
D = coil diameter
Arrangement of coils
Layout of the wire
  1. Perimeter stop test
  2. Perimeter tracking test
