Perimeter wire
Version vom 3. April 2015, 13:49 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Sender current control)
Magnetic field calculator
Principle:
Signal
  2. increase the signal length
We use a combination of both. The sender sends a repeating sequence of a digital code ('pseudonoise4_pw') at 9615 Hz :
Filter
sender circuit:
 motor driver M1OUT1     o---------- perimeter loop (20-450 meters, > 4 Ohm) --+
               |---------o-- GND
               |---------o-- Arduino +5V
Sender perimeter lawn size
Warning.png Note: For a short 20m wire (small R value), it is extremely difficult to set the correct DC voltage - if the voltage is too low, the motor driver shuts down sporadically (undervoltage detection), if the voltage is too high, the motor driver shuts down sporadically (overcurrent detection).
You can find the optimum current like this: First set IMAX pot to zero (0), and place robot in the center of the garden. Now, slowly increase IMAX pot, until 'qty' in the pfodApp plot ("Plot->Perimeter") increases (wait 20 seconds). Where quality ('qty') reaches its maximum, keep IMAX pot setting (qty=1.0 means poor quality, you should get qty=1.5 or higher).
Sender automatic standby
Sender software
Sender diagnostics
Video explaining all steps
Receiver
For receiving the signal, we use a coil (100 mH or 150 mH) in upright position (centered at front in robot), connected through a capacitor (4.7nF) to an LM386 operational amplifier (to amplify the received signal). When using the LM386 module, capacitor C3 on the LM386 module should be bypassed (which is needed so that the LM386 generates a signal between 0..5V and not the default range -5V..+5V). The LM386 output pin should be connected to an analog Arduino pin ('pinPerimeterLeft').
receiver circuit:
NOTE: It's recommended to directly mount the coil on the amplifier module. This ensures the 'small signal' of the coil is not distorted by other components (motors, DC/DC converters etc.)
The signal output of LM386 amplifier should look like this: (for more details about the signal, see section signal above)
Coil
The inductance of 100 mH and capacity of 4.7 nF results in a resonation frequency of 7341 Hz.
The inductance of 150 mH and capacity of 4.7 nF results in a resonation frequency of 5994 Hz.
f0 = 1 / (2 * PI * sqrt(L * C)) = 1 / (2 * PI * sqrt(0.15 H * 0,0000000047 F)) =  5994 Hz
Bandwidth = R / L = 155 Ohm / 0.15 H = 1033 Hz
Receiver ADC calibration
qty:  filter quality (filter min/max ratio - how distinguisable inside and outside were in filter result - 1.0 means poor quality)
  • Adjust voltage of sender: increase voltage (sender DC converter potentiometer) for for longer perimeter (>80m), decrease (sender potentiometer) for shorter perimeter (>25m) - Use 12V sender voltage (max. current), if 'mag' values are too low
  • While motors are running, try to tilt coil slightly to one side so that 'mag' curve improves (gets clearer without spikes)
Measurements
measurement:    AlexanderG_120m_loop
perimeter loop: length=120m
                R=7 ohm
                L=0.179 mH
sender:         Vpp(loop open)=24v    (DC=12V)
                Vpp(loop closed)=5v
receiver coil:  L=144 mH
                R=151 ohm
                Vpp(min)=20 mV
                Vpp(max)=150 mV
measurement:    AlexanderG_20m_loop
perimeter loop: length=20m
                R=2.5 ohm
                L=0.017 mH
sender:         Vpp(loop open)=10V     (DC=5V)
                Vpp=(loop closed)=8.6V
                R=151 ohm
                Vpp(min)=120 mV
                Vpp(max)=600 mV
note:           For a short 20m wire (small R value), it is extremely difficult to set the correct DC voltage -
  1. Perimeter2 demo
  2. 120m perimeter wire test
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
l = coil length
D = coil diameter
Arrangement of coils
Layout of the wire
  1. Perimeter stop test
  2. Perimeter tracking test
