Perimeter wire
Version vom 4. Mai 2015, 20:48 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Sender current control (in development))
Magnetic field calculator
Principle:
Signal
  2. increase the signal length
We use a combination of both. The sender sends a repeating sequence of a digital code ('pseudonoise4_pw') at 9615 Hz :
Filter
sender circuit:
 motor driver M1OUT1     o---------- perimeter loop (20-450 meters, > 4 Ohm) --+
               |---------o-- GND
               |---------o-- Arduino +5V
Sender perimeter lawn size
Warning.png Note: For a short 20m wire (small R value), it is extremely difficult to set the correct DC voltage - if the voltage is too low, the motor driver shuts down sporadically (undervoltage detection-Arduino LED starts to flash), and if the voltage is too high, the motor driver shuts down sporadically (overcurrent detection-Arduino LED starts to flash).
You can find the optimum current like this: First set IMAX pot to zero (0), and place robot in the center of the garden. Now, slowly increase IMAX pot, until 'qty' in the pfodApp plot ("Plot->Perimeter") increases (wait 20 seconds). Where quality ('qty') reaches its maximum, keep IMAX pot setting (qty=1.0 means poor quality, you should get qty=1.5 or higher).
MCP4151-5K version:
Vout = 1.23V*(1+VR1/R1)
Using VR1=5K...
Sender automatic standby
Sender software
Sender diagnostics
Video explaining all steps
Receiver
For receiving the signal, we use a coil (100 mH or 150 mH) in upright position (centered at front in robot), connected through a capacitor (4.7nF) to an LM386 operational amplifier (to amplify the received signal). When using the LM386 module, capacitor C3 on the LM386 module should be bypassed (which is needed so that the LM386 generates a signal between 0..5V and not the default range -5V..+5V). The LM386 output pin should be connected to an analog Arduino pin ('pinPerimeterLeft').
receiver circuit:
NOTE: It's recommended to directly mount the coil on the amplifier module. This ensures the 'small signal' of the coil is not distorted by other components (motors, DC/DC converters etc.)
The LM386 amplifier output should look like this: (for more details about the signal, see section signal above)
Coil
Some coil measurements:
Receiver ADC calibration
qty:  signal quality (filter min/max ratio - how distinguisable inside and outside were in filter result - 1.0 means poor quality,
      you should get 1.5 or higher)
  • Adjust voltage of sender: increase voltage (sender DC converter potentiometer) for for longer perimeter (>80m), decrease (sender potentiometer) for shorter perimeter (>25m) - For a short 20m wire (small R value), it is extremely difficult to set the correct DC voltage - if the voltage is too low, the motor driver shuts down sporadically (undervoltage detection-Arduino LED starts to flash), and if the voltage is too high, the motor driver shuts down sporadically (overcurrent detection--Arduino LED starts to flash).
Measurements
measurement:    AlexanderG_120m_loop
perimeter loop: length=120m
                R=7 ohm
                L=0.179 mH
sender:         Vpp(loop open)=24v    (DC=12V)
                Vpp(loop closed)=5v
receiver coil:  L=144 mH
                R=151 ohm
                Vpp(min)=20 mV
                Vpp(max)=150 mV
measurement:    AlexanderG_20m_loop
perimeter loop: length=20m
                R=2.5 ohm
                L=0.017 mH
sender:         Vpp(loop open)=10V     (DC=5V)
                Vpp=(loop closed)=8.6V
                R=151 ohm
                Vpp(min)=120 mV
                Vpp(max)=600 mV
note:           For a short 20m wire (small R value), it is extremely difficult to set the correct DC voltage -
  1. Perimeter2 demo
  2. 120m perimeter wire test
  4. Sender PCB
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
l = coil length
D = coil diameter
Arrangement of coils
Layout of the wire
  1. Perimeter stop test
  2. Perimeter tracking test
