Perimeter wire
Principle:
Signal
- increase the signal length
Filter
sender circuit:
motor driver M1OUT1 o---------- perimeter loop (20-450 meters, > 4 Ohm) --+
motor driver Vin o-- 12V
|---------o-- GND
|---------o-- Arduino +5V
Sender perimeter lawn size
Sender current control
Note: For a short 20m wire (small R value), it is extremely difficult to set the correct DC voltage -
if the voltage is too low, the motor driver shuts down sporadically (undervoltage detection-Arduino LED starts to flash), and
if the voltage is too high, the motor driver shuts down sporadically (overcurrent detection-Arduino LED starts to flash).
You can find the optimum current like this: First set IMAX pot to zero (0), and place robot in the center of the garden. Now, slowly increase IMAX pot, until 'qty' in the pfodApp plot ("Plot->Perimeter") increases (wait 20 seconds). Where quality ('qty') reaches its maximum, keep IMAX pot setting (qty=1.0 means poor quality, you should get qty=1.5 or higher).
MCP4151-5K version:
Vout = 1.23V*(1+VR1/R1)
Sender automatic standby
Sender software
Sender diagnostics
Receiver
receiver circuit:
NOTE: It's recommended to directly mount the coil on the amplifier module. This ensures the 'small signal' of the coil is not distorted by other components (motors, DC/DC converters etc.)
The LM386 amplifier output should look like this: (for more details about the signal, see section signal above)
Coil
Some coil measurements:
Receiver ADC calibration
qty: signal quality (filter min/max ratio - how distinguisable inside and outside were in filter result - 1.0 means poor quality,
you should get 1.5 or higher)
- Adjust voltage of sender: increase voltage (sender DC converter potentiometer) for for longer perimeter (>80m), decrease (sender potentiometer) for shorter perimeter (>25m) - For a short 20m wire (small R value), it is extremely difficult to set the correct DC voltage - if the voltage is too low, the motor driver shuts down sporadically (undervoltage detection-Arduino LED starts to flash), and if the voltage is too high, the motor driver shuts down sporadically (overcurrent detection--Arduino LED starts to flash).
Measurements
measurement: AlexanderG_120m_loop
perimeter loop: length=120m
R=7 ohm
L=0.179 mH
sender: Vpp(loop open)=24v (DC=12V)
Vpp(loop closed)=5v
receiver coil: L=144 mH
R=151 ohm
Vpp(min)=20 mV
Vpp(max)=150 mV
measurement: AlexanderG_20m_loop
perimeter loop: length=20m
R=2.5 ohm
L=0.017 mH
sender: Vpp(loop open)=10V (DC=5V)
Vpp=(loop closed)=8.6V
R=151 ohm
Vpp(min)=120 mV
Vpp(max)=600 mV
note: For a short 20m wire (small R value), it is extremely difficult to set the correct DC voltage -
- Perimeter2 demo
- 120m perimeter wire test
- Sender PCB
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
Arrangement of coils
Layout of the wire
