Troubleshooting ru
Error codes
* Check gear motor driver module and left gear motor
* Check gear motor driver module and right gear motor
* Check mower motor driver module and mower motor
ERR_IMU_TILT IMU tilt error
* Check coil polarity
* Check left odometry cable
* Check left motor direction
* Check right odometry cable
* Check right motor direction
ERR_BATTERY Battery error
* Check battery connections
ERR_CHARGER Charger error
* Check charger connections
* Check GPS cables
ERR_GPS_DATA GPS data error
* Check GPS antenna and cable
Motors working correctly
Some sensor not triggering?
Bluetooth not connecting?
Console output
--- commands ---
