Perimeter wire
How is the signal detected? The signal is detected by one receiver coils. The closer the distance between coil and perimeter loop, the higher the signal strength. Also, something interesting happens when the robot crosses the perimeter loop: the signal changes its polarity, that means positive and negative voltages reverse each other.
Sender principle:
Receiver principle:
  1. A coil receives the signal
Note for Marotronics INA169: Short pads for 5A operation
Sender software
Sender power control
Power:  P = U * I = 8 Volt * 0.7 Ampere => 5.6 Watt
Sender automatic standby
Sender diagnostics
The perimeter settings are:
* Coil to gear motor: > 15cm
* Coil to mower motor: > 10cm
Signal measurements
Receiver ADC calibration
Broken perimeter wire
  1. Perimeter2 demo
  2. 120m perimeter wire test
  4. Sender PCB
  5. Perimeter stop test
  6. Perimeter tracking test
