Ardumower PCB
Needed modules
All modules can be purchased as complete kits via the shop .
What is needed for the development of Ardumowers.
- Important modules to choose::
- Zubehör Set (Widerstände, Stiftleisten etc.)
- 2 x Protector Board
- 1 x Mega Board 2560 R3
- 1 x INA169 Strom Sensor Board
- 2 x Dual Treiber MC33926
- 3 x DC-DC LM2596 Step-Down Regler
- 1 x Wireless Bluetooth Modul HC-05
- 1 x Real Time Clock I2C DS1307
- 1 x 24 VoltLadegerät für den Ardumower Akku
- Optional modules::
- Zubehör Set Ladeschaltung (Blei Akkus)
- WIFI Wlan Modul ESP8266 ESP01
- Ultraschallsensoren HC-SR04 (bis zu 3 Stück werden unterstützt)
- Regensensor
- GPS Modul GY-GPS6MV2
- GYRO-80
- 1 x Perimeter Sender Board (Prototyp) mit Platinen Zubehör
- 1x Dual MC33926 Motor Driver Carrier
- 1x INA169 Analog DC Current Sensor Breakout - 60V 2,5A / 5A Marotronics
- 1 x DC-DC Spannungsregler LM2596 Step-Down Regler einstellbar
- 1 x Nano V3.0 ATmega328-AU Arduino kompatibel Mikrocontroller Board
- Gehäuse inklusive 5 passender Schrauben für das PCB
- Anschlussklemmen max.3 (2xSchleife, 1xLadeanschluss)
- Einbaubuchse für Gehäuse 2,5
- Additional accessories depending on needs:
- A charging station is in development and will follow soon.
- PCB dimensions 241x114mm
- Uses the Arduino Mega 2560
PCB versions
- Schematics
- Photos
- Build instructions
- WorkaRound20150527
- WorkaRound20150530
- Protector board
- motor driver protection
PCB jumpers
Feature used | YES | NO | Comment |
D7: DIODE
D7: SHORT-CIRCUIT
External power while charging (recommended: NO) | JP6: CLOSE
JP6: OPEN
Arduino controlled charge relay (recommended: YES) | JP4: CLOSE
JP5: OPEN |
JP4: OPEN
JP5: CLOSE |
Arduino Due (3.3V I/O) | LP0, ..., LP15: OPEN | LP0, ..., LP15: CLOSE | Do not use if using Arduino Mega |
Bluetooth VCC=3.3V | JP8: OPEN
JP9: CLOSE |
JP8: CLOSE
JP9: OPEN |
Bluetooth programming mode | JP2: CLOSE | JP2: OPEN | Use for reprogramming baud rate etc. |
PCB modules
Module | Feature | Pinout | Optional | Comment |
U1 | DC/DC converter (10V) | GND, Vout, Vin, GND | No | |
U2 | Bluetooth (HC-05) | VCC, GND, TXD, RXD, Key, LED | Yes | |
U3 | Current sensor (charging) | VCC, GND, OUT, IP+, IP-5 | Yes | |
U4 | Charge control (LM350T) | AJD, OUT, IN | Yes | |
U5 | Current sensor (charging) | VCC, GND, OUT, IP+, IP-5 | Yes | |
U6 | DC/DC converter (3.3V) | GND, Vout, Vin, GND | No | |
U7 | DC/DC converter (5V) | GND, Vout, Vin, GND | No | |
U8 | Realtime clock (DS1307) | Batt, GND, VCC, SDA, SCL, DS, SQ | Yes | |
U9 | Wifi (ESP8266) | TX, CH_PD, Reset, VCC, GND, GP_IO2, GP_IO0, RX | Yes | |
U10 | Level shifter 5V->3V (Arduino Due) | Yes | ||
U11 | Wifi (ESP8266) | TX, CH_PD, Reset, VCC, GND, GP_IO2, GP_IO0, RX | Yes | alternative mount position |
PCB connectors
Connector | Feature | Pinout | Optional | Comment |
P1 | Sonar center (HC SR-04) | 5V, GND, Trigger, Echo | Yes | |
P2 | Sonar right (HC SR-04) | 5V, GND, Trigger, Echo | Yes | |
P3 | Sonar left (HC SR-04) | 5V, GND, Trigger, Echo | Yes | |
P4 | reserved | Yes | ||
P5 | IMU (gyro,acceleration,compass) (GY-80) | Yes | ||
P6 | Lawn sensor | Yes | ||
P7 | Status LEDs | Yes | ||
P8 | Odometry right | Yes | ||
P9 | Odometry left | Yes | ||
P10 | GPS (GY-NEO6MV2) | Yes | ||
P11 | Bumper | GND, GND, right, left | Yes | |
P12 | Perimeter coil (center or left) | 5V, GND, perimeter | Yes | |
P13 | R/C remote control | 5V, GND, mow, steer, speed, switch | Yes | |
P14 | Measurement points | 5V, GND, (Depending on JP15: 3.3V, 5V or Arduino 3.3V) | Yes | |
P15 | Wheel motor left | M1OUT1, M1OUT2 | No | |
P16 | Optional motor driver input | Yes | Do not connect | |
P17 | Optional motor driver input | Yes | Do not connect | |
P18 | Wheel motor right | M2OUT1, M2OUT2 | No | |
P19 | Tilt sensor | 5V, GND, tilt | Yes | |
P20 | Button (Start/Stop) | No | ||
P21 | Drop sensor right | Yes | ||
P22 | Reserved | Yes | ||
P23 | Reserved | Yes | ||
P24 | Reserved | Yes | ||
P25 | Reserved | Yes | ||
P26 | Reserved | Yes | ||
P27 | Reserved | Yes | ||
P28 | Reserved | Yes | ||
P29 | Reserved | Yes | ||
P30 | Perimeter coil right | Yes | ||
P31 | Drop sensor left | Yes | ||
P32 | GND | Yes | ||
P33 | 5V | Yes | ||
P34 | 3.3V | Yes | ||
P35 | Mower motor RPM | Yes | ||
P36 | Reserved | Yes | ||
P37 | Mower motor | No | ||
P38 | Reserved | Yes | ||
P39 | Reserved | Yes | ||
P40 | User switches | Yes | ||
P41 | Rain sensor | Yes | ||
P42 | Charging pins | Yes | ||
P43 | Battery (24V) | No | ||
P44 | Wifi module (ESP8266) | Yes | ||
P45 | Reserved | Yes | ||
P46 | Reserved | Yes |
Warning : never connect more than 5V on the Arduino 5V pins, or you will damage the Arduino. Therefore, always measure the 5V voltage before connecting it to the Arduino 5V pin! All components together (as shown in the schematics) need about 5W power.
You have two options:
First-time calibration
Wheel motors
20 OFF spd 0 0 0 sen 0 0 0 bum 0 0 son... 21 OFF spd 0 0 0 sen 0 0 0 bum 0 0 son... 22 OFF spd 0 0 0 sen 0 0 0 bum 0 0 son... 23 OFF spd 0 0 0 sen 0 0 0 bum 0 0 son... 24 OFF spd 0 0 0 sen 0 0 0 bum 0 0 son... ...
ADC calibration
Run the ADC calibration once (either via serial console with command 'd' or "pfodApp->ADC Calibration"), so that the received signal is symmetric around zero.
Diagnostics/troubleshooting
- loop()-counts per second
- drive home? (1/0)
- "com" - compass course
- "bat" - Battery voltage
- "chg" - Charging current
Starting the mower
Error counter / error beeps
I2C bus / error beeps
