Perimeter wire
Version vom 29. Mai 2016, 23:57 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Perimeter v1 (for old v0.9.3 code, not recommended))
Magnetic field calculator
Principle:
Signal
  2. increase the signal length
We use a combination of both. The sender sends a repeating sequence of a digital code ('pseudonoise4_pw') at 9615 Hz :
Filter
Sender perimeter lawn size
area = PI * (r*r) = PI * (18m * 18m) = 1000 m2
Sender current control
  • DC/DC Voltage: The motor driver supply voltage can be changed (6.5-12V via the potentiometer on the DC converter). That's one way to do it and it's the recommended way. NOTE: The minimum voltage (Vin) for the MC33926 motor driver is 5v. If the voltage is lower, the motor driver shuts down sporadically (undervoltage detection-Arduino LED starts to flash).
  • Normal amplitude: Instead of switching the perimter wire between +Vin and -Vin (double amplitude/default), the motor driver can switch it between +Vin and GND (normal amplitude). This will reduce current. To use normal amplitude, comment out the corresponding code line in 'sender.ino':
  • Power resistor: If your perimeter wire resistance (R) is below 5 Ohms, you will not be able to further reduce voltage below 6.5v (otherwise the Arduino will not work properly). Then you have to increase the perimeter wire resistance (R) by using a power resistor (example: 5 ohm, 10W) in series with your perimeter wire.
@6 volts (Vin): 5 ohm power resistor => I=U/R=6v/5ohm=1.2A   (P=U*I=6v*1.2A=7.2W)
MCP4151-5K version:
Vout = 1.23V*(1+VR1/R1)
Using VR1=5K...
Sender automatic standby
Sender software
Sender diagnostics
Video explaining all steps
Receiver
pfodApp->Options->Perimeter->"Timed-out if below smag" (timedOutIfBelowSmag) - default setting: 300 | If smag below this value, sender is considered as off (perimeter timeout appears)
pfodApp->Options->Perimeter->"Timeout (s) if not inside" (timeOutSecIfNotInside) - default setting: 8
pfodApp->Options->Perimeter->"Trigger timeout" (perimeterTriggerTimeout) - default setting: 0 | Perimeter outside trigger timeout when escaping from inside (ms)
pfodApp->Options->Perimeter->"Perimeter out roll time max" (perimeterOutRollTimeMax) - default setting: 2000 | Max (random generator) roll time after perimeter out (ms)
pfodApp->Options->Perimeter->"Perimeter out roll time min" (perimeterOutRollTimeMin) - default setting: 750 | Min (random generator) roll time after perimeter out (ms)
pfodApp->Options->Perimeter->"Perimeter out reverse time" (perimeterOutRevTime) - default setting: 2200 | Time to drive reverse after perimeter out (ms)
pfodApp->Options->Perimeter->"Perimeter tracking roll time" (perimeterTrackRollTime) - default setting: 1500 | Hit obstacle while tracking: roll time
pfodApp->Options->Perimeter->"Perimeter tracking reverse time" (perimeterTrackRevTime) - default setting: 2200 | Hit obstacle while tracking: reverse time
pfodApp->Options->Perimeter->"Transition timeout" (trackingPerimeterTransitionTimeOut) - default setting: 2000 | Max. time required for a in/out transition during tracking, robot will start rotating after this timeout
pfodApp->Options->Perimeter->"Track error timeout" (trackingErrorTimeOut) - default setting: 10000 | Max. time required for a in/out transition during tracking, robot will go into error after this time
pfodApp->Options->Perimeter->"Track_P" (perimeterPID.Kp) - default setting:51 | Perimeter PID "P" setting
pfodApp->Options->Perimeter->"Track_I" (perimeterPID.Ki) - default setting:12.5 | Perimeter PID "I" setting
pfodApp->Options->Perimeter->"Track_D" (perimeterPID.Kd) - default setting:0.8 | Perimeter PID "D" setting
pfodApp->Options->Perimeter->"Use differential signal" (useDifferentialPerimeterSignal) - default setting: YES | Use differential signal (see signal section)
pfodApp->Options->Perimeter->"Swap coil polarity" (swapCoilPolarity) - default setting:NO
pfodApp->Options->Perimeter->"Block inner wheel" (trackingBlockInnerWheelWhilePerimeterStruggling) - default setting: YES | robot is wheel-spinning while tracking => roll to get ground again
* Coil to gear motor: > 15cm
* Coil to mower motor: > 10cm
Signal measurements
Coil and noise measurements
Receiver ADC calibration
  • Adjust voltage of sender: increase voltage (sender DC converter potentiometer) for for longer perimeter (>80m), decrease (sender potentiometer) for shorter perimeter (>25m)
Broken perimeter wire
Measurements
Noise (max): smag=192
Signal (min): smag=254
SNR=Signal/Noise=254/192=1.3
Signal (min): smag=896
SNR=Signal/Noise=896/192=4.6
  1. Perimeter2 demo
  2. 120m perimeter wire test
  4. Sender PCB
  1. Perimeter stop test
  2. Perimeter tracking test
