Ardumower PCB
Needed modules
What is needed for the assembly of Ardumower
- Important modules to choose:
- Zubehör Set (Widerstände, Stiftleisten etc.)
- 2 x Protector Board
- 1 x Mega Board 2560 R3
- 1 x INA169 Strom Sensor Board
- 2 x Dual Treiber MC33926
- 3 x DC-DC LM2596 Step-Down Regler
- 1 x Wireless Bluetooth Modul HC-05
- 1 x Real Time Clock I2C DS1307
- 1 x 24 Volt Ladegerät für den Ardumower Akku
- Optional modules:
- Zubehör Set Ladeschaltung (Blei Akkus)
- WIFI Wlan Modul ESP8266 ESP01
- Ultraschallsensoren HC-SR04 (bis zu 3 Stück werden unterstützt)
- Regensensor
- GPS Modul GY-GPS6MV2
- GYRO-80
- 1x Dual MC33926 Motor Driver Carrier
- 1x INA169 Analog DC Current Sensor Breakout - 60V 2,5A / 5A Marotronics
- 1 x DC-DC Spannungsregler LM2596 Step-Down Regler einstellbar
- 1 x Nano V3.0 ATmega328-AU Arduino kompatibel Mikrocontroller Board
- Optional modules:
- Gehäuse inklusive 5 passender Schrauben für das PCB
- Anschlussklemmen max.3 (2xSchleife, 1xLadeanschluss)
- Einbaubuchse für Gehäuse 2,5
- Additional accessories depending on needs:
- A charging station is in development and will follow soon.
- PCB dimensions 241x114mm
- Uses the Arduino Mega 2560
PCB building manual
- Schematics
- Photos
- Build instructions
- WorkaRound20150527
- WorkaRound20150530
- Protector board (required for safe-use of motor drivers!)
- based on Arduino Due
- shields for motor controller, perimeter receiver, etc.
- battery-off circuit
PCB jumpers
D7: DIODE
D7: SHORT-CIRCUIT
JP6: OPEN
JP5: OPEN |
JP4: OPEN
JP5: CLOSE |
JP9: CLOSE |
JP8: CLOSE
JP9: OPEN |
PCB modules
PCB connectors
| P4 | reserved | Yes | ||
| P6 | Lawn sensor | Yes | ||
| P7 | Status LEDs | Yes | ||
| P22 | Reserved | Yes | ||
| P23 | Reserved | Yes | ||
| P24 | Reserved | Yes | ||
| P25 | Reserved | Yes | ||
| P26 | Reserved | Yes | ||
| P27 | Reserved | Yes | ||
| P28 | Reserved | Yes | ||
| P29 | Reserved | Yes | ||
| P32 | GND | Yes | ||
| P33 | 5V | Yes | ||
| P34 | 3.3V | Yes | ||
| P36 | Reserved | Yes | ||
| P37 | Mower motor | No | ||
| P38 | Reserved | Yes | ||
| P39 | Reserved | Yes | ||
| P45 | Reserved | Yes | ||
| P46 | Reserved | Yes |
You have two options:
Important for Arduino IDE 1.6 or higher: if you see any folders inside the code folder (e.g. 'unused'), please delete them before compilation! Note: Always verify that the pin configuration in your Arduino code (config.h/mower.cpp) matches your actual circuit!
First-time usage
1. Deactive all sensors:
At first deactivate all sensors - In 'mower.cpp' set the robot settings like this: bumperUse = 0; dropUse = 0; rainUse = 0; sonarUse = 0; perimeterUse = 0; lawnSensorUse = 0; imuUse = 0; batMonitor = 0; odometryUse = 0; gpsUse = 0; buttonUse = 1; timerUse = 0;
2. The software offers a serial console mode. Open the serial console in the Arduino IDE (CTRL+SHIFT+M) and set the baudrate to 19200. The motor and sensor values should appear constantly. First let's delete any existing error:
4. Test motors:
Console: press... d for menu 1=test motorsSecurity note: For security reasons, always remove mower blades in your first tests!
Diagnostics/troubleshooting
- loop()-counts per second
- drive home? (1/0)
- "com" - compass course
- "bat" - Battery voltage
- "chg" - Charging current
Error codes and troubleshooting
Starting the mower
Error counter / error beeps
I2C bus / error beeps
