Perimeter wire
How is the signal detected? The signal is detected by one receiver coils. The closer the distance between coil and perimeter loop, the higher the signal strength. Also, something interesting happens when the robot crosses the perimeter loop: the signal changes its polarity, that means positive and negative voltages reverse each other.
Perimeter
Sender principle:
Receiver principle:
- A coil receives the signal
The images below explain why the polarity of the received coil signal changes between inside and outside of the perimeter wire. The image shows the direction of the electric flux lines sent out from the perimeter wire and how they hit the coil for both inside and outside position. For a better understanding of the perimeter filter, see the Matched filter simulation. For more details about the filter, also see the Matched filter video.
The perimeter wire length should be in the range 20m - 450m and must be at least 5 Ohm and not more than 12 Ohm. The maximum perimeter area is 1000 m2.
Sender software
Sender power control
The perimeter wire resistance (R) must be at least 5 Ohm and not more than 12 Ohm.
Your perimeter wire resistance (R): 12 Ohm Your adjusted voltage at the DC/DC converter: 8 Volt
Current: I = U / R = 8 Volt / 12 Ohm => 0.7 Ampere Power: P = U * I = 8 Volt * 0.7 Ampere => 5.6 Watt
Sender automatic standby
The sender can be switched off during the time the robot is in the charging station. To detect the robot, a current sensor is connected between the charger and the charging pins.
Sender diagnostics
Receiver
The perimeter settings are:
Signal measurements
Receiver ADC calibration
Broken perimeter wire
Measurements
Noise (max): smag=192 Signal (min): smag=254 SNR=Signal/Noise=254/192=1.3
Noise (max): smag=192 Signal (min): smag=896 SNR=Signal/Noise=896/192=4.6
- Perimeter2 demo
- 120m perimeter wire test
- Sender PCB
- Perimeter stop test
- Perimeter tracking test
