Perimeter wire
Version vom 12. Juni 2016, 09:46 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Sender automatic standby)
How is the signal detected? The signal is detected by one receiver coils. The closer the distance between coil and perimeter loop, the higher the signal strength. Also, something interesting happens when the robot crosses the perimeter loop: the signal changes its polarity, that means positive and negative voltages reverse each other.
Perimeter
Sender principle:
Receiver principle:
  1. A coil receives the signal
The images below explain why the polarity of the received coil signal changes between inside and outside of the perimeter wire. The image shows the direction of the electric flux lines sent out from the perimeter wire and how they hit the coil for both inside and outside position. For a better understanding of the perimeter filter, see the Matched filter simulation. For more details about the filter, also see the Matched filter video.
Note for Marotronics INA169: Short pads for 5A operation
Sender software
Sender power control
Power:  P = U * I = 8 Volt * 0.7 Ampere => 5.6 Watt
Sender diagnostics
Receiver
The perimeter settings are:
* Coil to gear motor: > 15cm
* Coil to mower motor: > 10cm
Signal measurements
Receiver ADC calibration
Broken perimeter wire
  1. Perimeter2 demo
  2. 120m perimeter wire test
  4. Sender PCB
  5. Perimeter stop test
  6. Perimeter tracking test
