PCB 1.2 (English)
- 1 Abstract
- 2 Needed modules
- 3 PCB
- 4 Power supply
- 5 Motors
- 6 Voltages
- 7 Motor driver assembly (dual MC33926)
- 8 Protector PCB
- 9 Wheel motors wiring
- 10 Wheel motors odometry wiring
- 11 Mower motor wiring
- 12 Motor decrease noise
- 13 Motor controller (PID)
- 14 Bluetooth module
- 15 Bluetooth module
- 16 Bluetooth HC-05
- 17 Bluetooth module configuration steps
- 18 PC/Mac remote control application
- 19 Communication protocol
- 20 Sensor logging
- 21 Videos
- 22 Charger
- 23 Total power balance
- 24 Battery
- 25 Standby-off / Under-voltage protection
- 26 Robot charging
- 27 Charging station
- 28 Videos
Needed modules
- PCB dimensions 241x114mm
- Uses the Arduino Mega 2560
PCB building manual
- Schematics
- Photos
- Build instructions
- WorkaRound20150527
- WorkaRound20150530
PCB building videos
- Resistors
- Diodes and relay
- Capacitors and transistors
- Piezo buzzer and fuse
- Strip pins
- DC/DC converter
- RTC module
- Dual MC33926
- INA169
- Battery & charger
PCB jumpers
D7: DIODE
D7: SHORT-CIRCUIT
JP6: OPEN
JP5: OPEN |
JP4: OPEN
JP5: CLOSE |
JP9: CLOSE |
JP8: CLOSE
JP9: OPEN |
PCB modules
PCB connectors
| P4 | reserved | Yes | ||
| P6 | Lawn sensor | Yes | ||
| P7 | Status LEDs | Yes | ||
| P22 | Reserved | Yes | ||
| P23 | Reserved | Yes | ||
| P24 | Reserved | Yes | ||
| P25 | Reserved | Yes | ||
| P26 | Reserved | Yes | ||
| P27 | Reserved | Yes | ||
| P28 | Reserved | Yes | ||
| P29 | Reserved | Yes | ||
| P32 | GND | Yes | ||
| P33 | 5V | Yes | ||
| P34 | 3.3V | Yes | ||
| P36 | Reserved | Yes | ||
| P37 | Mower motor | No | ||
| P38 | Reserved | Yes | ||
| P39 | Reserved | Yes | ||
| P45 | Reserved | Yes | ||
| P46 | Reserved | Yes |
Motors
Voltages
Protector PCB
Wheel motors wiring
- steer the robot left/right
Wheel motor features:
- 24V (load current ~1A)
Motor wiring (left motor):
Mower motor wiring
Bluetooth module
The phone menu includes:
- Settings (Timer etc.)
Bluetooth module
Bluetooth HC-05
Example communication:
title [text1] [text2] [text3]
Sensor logging
Charger
Total power balance
Battery
Robot charging
Charging station
Ultrasonic Sensor
An ultrasonic sensor (HC-SR04) allows Ardumower to detect obstacles.
Distance 2 to 450 cm
Wiring
Ultrasonic Module VCC (+5V) — PCB VCC (+5V) Ultrasonic Module GND — PCB GND Ultrasonic Module Trigger — PCB Digital Pin Ultrasonic Module Echo — PCB Digital Pin
An internal schematics of the sensor can be found here.[1]
