PCB 1.2 (English)
Version vom 2. Juli 2017, 11:08 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Communication protocol)
Needed modules
  • PCB dimensions 241x114mm
  • Uses the Arduino Mega 2560
PCB building manual
PCB building videos
PCB jumpers
Feature used YES NO Comment
D7: DIODE
D3: DIODE
C1, C4, U4, RV1: used
D7: SHORT-CIRCUIT
D3: SHORT-CIRCUIT
C1, C4, U4, RV1: not used
JP7: OPEN
D4: DIODE
C5: not used
JP6: OPEN
JP7: CLOSE
D4: SHORT-CIRCUIT
C5: used
JP5: OPEN
JP4: OPEN
JP5: CLOSE
Bluetooth VCC=3.3V JP8: OPEN
JP9: CLOSE
JP8: CLOSE
JP9: OPEN
Many latest modules use 3.3V
PCB modules
Note for Marotronics INA169: Short pads for 5A operation
PCB connectors
P4 reserved Yes
P6 Lawn sensor Yes
P7 Status LEDs Yes
P8 Odometry right Yes
P9 Odometry left Yes
P10 GPS (GY-NEO6MV2) Yes
P20 Button (Start/Stop) No
P21 Drop sensor right Yes
P22 Reserved Yes
P23 Reserved Yes
P24 Reserved Yes
P25 Reserved Yes
P26 Reserved Yes
P27 Reserved Yes
P28 Reserved Yes
P29 Reserved Yes
P30 Perimeter coil right Yes
P31 Drop sensor left Yes
P32 GND Yes
P33 5V Yes
P34 3.3V Yes
P35 Mower motor RPM Yes
P36 Reserved Yes
P37 Mower motor No
P38 Reserved Yes
P39 Reserved Yes
P40 User switches Yes
P41 Rain sensor Yes
P42 Charging pins Yes
P43 Battery (24V) No
P44 Wifi module (ESP8266) Yes
P45 Reserved Yes
P46 Reserved Yes
Motors
Voltages
Protector PCB
Wheel motors wiring
  • steer the robot left/right
Wheel motor features:
  • 24V (load current ~1A)
Motor wiring (left motor):
Wheel motors odometry wiring
Motor (brown)  ---- PCB VCC
Motor (green)  ---- PCB GND
Mower motor wiring
Motor decrease noise
Motor controller (PID)
Bluetooth module
  • via phone/tablet (Android App)
  • via USB Bluetooth dongle (PC serial console)
The phone menu includes:
  • Status information (battery voltage, charging current etc.)
  • Settings (Timer etc.)
  • Calibration (Motor, IMU etc.)
  • Remote control (Start/Stop, Switching on/off mower motor, blade modulation etc.)
Bluetooth module
Bluetooth HC-05
Bluetooth HC05 TX  --- PCB RX
Bluetooth HC05 RX  --- PCB TX
Bluetooth module configuration steps
  1. Configuration mode: The Bluetooth module must be in configuration mode for the next step:
    1. for HC05: Connect KEY pin to 3.3V after powering on the module
    2. for HC06/linvor: Do NOT pair/connect (LED must be blinking)
    3. for FBT06/MBTV4: First you have to solder the PIO11 pin to VCC (PIN 12) which is 3.3 Volts using a thin wire.
  2. Baud rate: Blueooth module and Arduino Mega must use the same baud rate (19200) - The baud rate of the BT module can be changed via Ardumower serial console. Connect Ardumower Mega board to your PC (USB), enter the serial console in the Arduino IDE (CTRL+M), and choose baud rate 19200, then choose 'd' to enter the Ardumower menu, '3' for communications menu, and '3' to configure the module to the correct baud rate.
  3. Restart: After your BT module is configured successfully, remove KEY pin connection again (HC05), and restart module.
  4. Pairing: The BT module must be 'paired' with your Android device once (via Android device settings). On the Android device, choose symbol "Settings" (via Android menu). Now choose "Wirless and Networks->Bluetooth Settings" and "Find device". Finally, choose "pair with this device" and enter your pin (very often "1234"). The Bluetooth module should now appear as "paired".
  5. pfodApp: Now you can start pfodApp/ArduRemote to connect to the Ardumower.
Sensor logging
  1. menu demo v0.8.8
  2. menu demo live v0.8.8
  3. tutorial video
Charger
Total power balance
Battery
schematics
Robot charging
Charging station
  2. Drive in and out
  3. Tracking and docking
  4. Final version
Ultrasonic Sensor
An ultrasonic sensor (HC-SR04) allows Ardumower to detect obstacles.
Distance 2 to 450 cm
Wiring
Ultrasonic Module Trigger    — PCB Digital Pin
Ultrasonic Module Echo       — PCB Digital Pin
An internal schematics of the sensor can be found here.[1]
