PCB 1.2 (English)
- 1 Required parts for the Ardumower
- 2 Abstract
- 3 Needed modules
- 4 PCB
- 5 Power supply
- 6 Motors
- 7 Voltages
- 8 Motor driver assembly (dual MC33926)
- 9 Protector PCB
- 10 Wheel motors wiring
- 11 Wheel motors odometry wiring
- 12 Mower motor wiring
- 13 Motor decrease noise
- 14 Motor controller (PID)
- 15 Bluetooth module
- 16 Bluetooth module
- 17 Bluetooth HC-05
- 18 Bluetooth module configuration steps
- 19 PC/Mac remote control application
- 20 Communication protocol
- 21 Sensor logging
- 22 Videos
- 23 Charger
- 24 Total power balance
- 25 Battery
- 26 Standby-off / Under-voltage protection
- 27 Robot charging
- 28 Charging station
- 29 Videos
- 30 Rain sensor
- 31 Wiring
- 32 Photos
- 33 Videos
- 34 Further links
What is needed for building your Ardumower:
- The Ardumower chassis including motors
- Important modules to choose:
- Accessories Set (resistors, pin strips etc.)
- 2 x Motor driver protection PCB
- 1 x Mega Board 2560 R3
- 1 x INA169 Current Sensor Board
- 2 x Dual motor driver MC33926
- 2 x DC-DC LM2596 Step-Down Converter
- 1 x Wireless Bluetooth module HC-05
- 1 x Real Time Clock I2C DS1307
- 1 x 24 Volt Charger for the Ardumower LithiumIon Battery
- Optional modules:
- 1 x Ardumower Power Pack
- 1 x 3 mowing blades + 3 screws, e.g. suitable for Automower® from Husqvarna®
Needed modules
- PCB dimensions 241x114mm
- Uses the Arduino Mega 2560
PCB building manual
- Schematics
- Photos
- Build instructions
- WorkaRound20150527
- WorkaRound20150530
PCB building videos
- Resistors
- Diodes and relay
- Capacitors and transistors
- Piezo buzzer and fuse
- Strip pins
- DC/DC converter
- RTC module
- Dual MC33926
- INA169
- Battery & charger
PCB jumpers
D7: DIODE
D7: SHORT-CIRCUIT
JP6: OPEN
JP5: OPEN |
JP4: OPEN
JP5: CLOSE |
JP9: CLOSE |
JP8: CLOSE
JP9: OPEN |
PCB modules
PCB connectors
| P4 | reserved | Yes | ||
| P6 | Lawn sensor | Yes | ||
| P7 | Status LEDs | Yes | ||
| P22 | Reserved | Yes | ||
| P23 | Reserved | Yes | ||
| P24 | Reserved | Yes | ||
| P25 | Reserved | Yes | ||
| P26 | Reserved | Yes | ||
| P27 | Reserved | Yes | ||
| P28 | Reserved | Yes | ||
| P29 | Reserved | Yes | ||
| P32 | GND | Yes | ||
| P33 | 5V | Yes | ||
| P34 | 3.3V | Yes | ||
| P36 | Reserved | Yes | ||
| P37 | Mower motor | No | ||
| P38 | Reserved | Yes | ||
| P39 | Reserved | Yes | ||
| P45 | Reserved | Yes | ||
| P46 | Reserved | Yes |
Motors
Voltages
Protector PCB
Wheel motors wiring
- steer the robot left/right
Wheel motor features:
- 24V (load current ~1A)
Motor wiring (left motor):
Mower motor wiring
Bluetooth module
The phone menu includes:
- Settings (Timer etc.)
Bluetooth module
Bluetooth HC-05
Sensor logging
Charger
Total power balance
Battery
Robot charging
Charging station
Ultrasonic Sensor
An ultrasonic sensor (HC-SR04) allows Ardumower to detect obstacles.
Distance 2 to 450 cm
Wiring
Ultrasonic Module VCC (+5V) — PCB VCC (+5V) Ultrasonic Module GND — PCB GND Ultrasonic Module Trigger — PCB Digital Pin Ultrasonic Module Echo — PCB Digital Pin
An internal schematics of the sensor can be found here.[1]
Rain sensor
Using a rain sensor, your Ardumower can stop mowing when it starts to rain. Additionally, it can drive into your charging station.
NOTE: If using YL-83 module, we have no long-term experience regarding corrosion!
Wiring
GND o-----o GND Rain sensor module
+5V o-----o VCC Rain sensor module
Ardumower pinRain o-----o D0 Rain sensor module
Rain sensor module IN o----- rain sensor
