Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 14 Odometry test
- 15 RTK GPS test (invalid, float, fix)
- 16 Discussion / questions / forum thread
- 17 How the waypoints are generated
- Demo: Path planning and mowing demo video
- Demo: Docking demo video (showing cm-precise RTK)
- Optimized for Arduino Due
- Incomplete (Sunray is 'work in progress') - features like docking, GPS signal-loss detection, obstacle detection and avoidance are going to be added soon.
- Experimental (never run your Ardumower unattended with this firmware)
GPS->XBEE | should blink - your base module is sending satellite reference data to your rover module (via the XBee module) |
XBEE->GPS | should be OFF - your base module should not receive any XBee signal |
GPS FIX | should be ON - your base module has found a valid GPS signal |
NO RTK | should be ON - your base module is not performing RTK (real time kinematic) |
Rover: 'GPS->XBEE' should be OFF - your rover module should not send any XBee signal 'XBEE->GPS' should blink - your rover module is receiving satellite reference data from your base module (via the XBee module) 'GPS FIX' should be ON - your rover module has found a valid GPS signal 'NO RTK' should be OFF - your rover module has found a RTK FIX (real time kinematic)
