Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 14 Odometry test
- 15 RTK GPS test (invalid, float, fix)
- 16 Discussion / questions / forum thread
- 17 How the waypoints are generated
- Demo: Path planning and mowing demo video
- Demo: Docking demo video (showing cm-precise RTK)
- Optimized for Arduino Due
| GPS->XBEE | should blink - your base module is sending satellite reference data to your rover module (via the XBee module) |
| XBEE->GPS | should be OFF - your base module should not receive any XBee signal |
| GPS->XBEE | should be OFF - your rover module should not send any XBee signal |
| XBEE->GPS | should blink - your rover module is receiving satellite reference data from your base module (via the XBee module) |
| NO RTK | should be OFF - your rover module has found a RTK FIX (is performing real-time kinematic) |
