Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 14 Odometry test
- 16 Discussion / questions / forum thread
- 17 How the waypoints are generated
- Optimized for Arduino Due
NOTE: If you purchased your RTK-GPS modules at Marotronics, these modules should be pre-configured and you can skip this section. You can download the ublox F9P config files (with the changes below) here: https://github.com/Ardumower/Sunray.
| age | The age (in seconds) of the DGPS correction data (sent via the XBee module) |
| XBEE>GPS | should be OFF - your base module should not receive any XBee signal |
