Ardumower Sunray
Version vom 24. Februar 2020, 16:34 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Method 1: Your own RTK base)
Video.png Click below to watch demo and tutorial videos:
PCB     PCB
  • Optimized for Arduino Due
PCB     PCB
NOTE: If you purchased your RTK-GPS modules at Marotronics, these modules should be pre-configured and you can skip this section. You can download the ublox F9P config files (with the changes below) here: https://github.com/Ardumower/Sunray.
age The age (in seconds) of the DGPS correction data (sent via the XBee module)
600px
