Ardumower Sunray
Version vom 27. Februar 2020, 09:36 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Method 1: Your own RTK base)
PCB     PCB
  • Optimized for Arduino Due
PCB     PCB
XBee RF modules issues
You can change the message rates at the base via the configuration of the CFG-MSG message, choosing the above RTCM3 message and setting zero (0) to turn a a RTCM3 message off or a non-zero rate value for the message rate. For example setting the rate to 1 means every second, 2 means every two seconds etc. Do not forget to send and save the base configuration.
600px
