Ardumower Sunray
Version vom 27. Februar 2020, 09:39 Uhr von Alexanderg (Diskussion | Beiträge) (→‎What is RTK and what are the requirements (environment and hardware))
RTK-GPS uses two GPS receivers, one for the reference antenna (base) and one for the robot mower (rover) which both communicate in realtime via radio modules. The base constantly sends correction data so the rover can compute its cm-precise (relative) position. In the RTK-GPS kit, everything required (receivers, radios, antennas etc.) is included. Also, if you don't want to operate your own RTK base, you can use an external base service via Internet (e.g. like Germany's SAPOS).
PCB     PCB
  • Optimized for Arduino Due
PCB     PCB
XBee RF modules issues
You can change the message rates at the base via the configuration of the CFG-MSG message, choosing the above RTCM3 message and setting zero (0) to turn a a RTCM3 message off or a non-zero rate value for the message rate. For example setting the rate to 1 means every second, 2 means every two seconds etc. Do not forget to send and save the base configuration.
600px
