Ardumower Sunray
Version vom 29. Februar 2020, 08:53 Uhr von Alexanderg (Diskussion | Beiträge) (→‎What is RTK and what are the requirements (environment and hardware))
RTK-GPS uses two GPS receivers, one for the reference antenna (base) and one for the robot mower (rover) which both communicate in realtime via radio modules. The base constantly sends correction data so the rover can compute its cm-precise (relative) position. In the RTK-GPS kit, everything required (receivers, radios, antennas etc.) is included. Also, if you don't want to operate your own RTK base, you can use an external base service via Internet (e.g. like Germany's SAPOS).
  • Optimized for Arduino Due
PCB     PCB
XBee RF modules issues
u-blox GNSS Multiband antenna ANN-MB-00:                28 dB
Lightweight helical antenna for multiband GNSS (IP67):  33 dB
Survey GNSS Multiband antenna (IP66):                   40 dB
600px
