Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 14 Odometry test
- 16 XBee RF modules issues
- 17 GPS antenna selection guide
- 18 Discussion / questions / forum thread
- 19 How the waypoints are generated
RTK-GPS uses two GPS receivers, one for the reference antenna (base) and one for the robot mower (rover) which both communicate in realtime via radio modules. The base constantly sends correction data so the rover can compute its cm-precise (relative) position. In the RTK-GPS kit, everything required (receivers, radios, antennas etc.) is included. Also, if you don't want to operate your own RTK base, you can use an external base service via Internet (e.g. like Germany's SAPOS). This will reduce the hardware cost by about half.
- Optimized for Arduino Due
u-blox GNSS Multiband antenna ANN-MB-00: 28 dB Lightweight helical antenna for multiband GNSS (IP67): 33 dB Survey GNSS Multiband antenna (IP66): 40 dB
