Ardumower Sunray
Version vom 3. März 2020, 17:58 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Assembling the chassis and PCB)
RTK example environments
This section shows some of the environments where we successfully tested RTK GPS.
Environment 'AG' (mostly open sky) PCB
  • Optimized for Arduino Due
PCB     PCB
XBee RF modules issues
We are currently experimenting with different GPS antennas for the rover. The helical and survey antennas seem to perform slightly better than the normal patch antennas. A RTK-FIX solution is obtained more quickly and hold longer in challenging lawn environments with them.
Recording perimeter polygon and exclusions polygons
600px
