Ardumower Sunray
- 3 RTK example environments
- 4 Assembling the chassis and PCB
- 5 Significant changes compared to Ardumower's initial firmware (Sunray vs. Azurit)
- 6 Installation steps
- 7 Bluetooth BLE UART module
- 8 PCB1.3 GPS pin fix
- 9 PCB1.3 odometry divider
- 10 RTK base
- 11 RTK rover
- 14 Phone App
- 15 Odometry test
- 17 XBee RF modules issues
- 18 GPS antenna selection guide
- 19 Bluetooth Low Energy (BLE) external antenna hack
- 20 Recording perimeter polygon and exclusions polygons
- 21 How the waypoints are generated
- 22 Discussion / questions / forum thread
This section shows some of the environments where we successfully tested RTK GPS.
- Optimized for Arduino Due
We are currently experimenting with different GPS antennas for the rover. The helical and survey antennas seem to perform slightly better than the normal patch antennas. A RTK-FIX solution is obtained more quickly and hold longer in challenging lawn environments with them.
